Subject Topic: Headlight Housing Fogged Up Post ReplyPost New Topic
Geno
Posted: Nov 04 2004 at 9:42pm | IP Logged Quote Geno
Ok.....I'm on a roll tonight. First it's the service engine light and now I notice that my driver side headlight housing is all fogged up with internal moisture. I don't believe this is supposed to happen. Please correct me if I'm wrong.
Thanks,
Geno
Back to Top View Geno's Profile Search for other posts by Geno
Posted: Nov 05 2004 at 1:40pm | IP Logged Quote thepuffman
Nope its not...I think I saw a post about a TSB for that.....
Try doin a search on "headlamp moisture fogging"
Geno
Posted: Nov 05 2004 at 6:53pm | IP Logged Quote Geno
Called the dealer today and they said they there is weep holes on the assembly that would allow moisture in....but should also allow it to evaporate.....if it doesn't then the holes are clogged and need to be fixed. As of right now the lens is clear and so that is OK.
