Todd TCE Senior Member
Posted: Nov 05 2004 at 11:08am | IP Logged
Tired of that BBBB, BBBB, BBBB everytime you have the door ajar? Or you want to blast some tunes with all the doors open?
Crawl under the dash, look to the left side of the key barrel assembly, on it is a white plastic 'thingy' and plugged into it is a white multi pin connector which may have some foam around it. Unplug this connector and your beep will be gone.
I've driven a bit with the dash apart to see if it has any other effects. As of now I find none. The headlamps probably won't beep either now. Other than these two thing everything else looks fine.
vector6 Groupie
Online Status: Offline Posts: 55
Posted: Nov 05 2004 at 3:50pm | IP Logged
DUDE !!! thats the self destruct connector....
Just dont go over 88 MPH....
__________________ 2006 JEEP Rubicon
No News with Combat Crews!!
fox92020 Groupie
Online Status: Offline Posts: 56
Posted: Nov 05 2004 at 4:26pm | IP Logged
Doesn't that also warn you, along with warning lights, of low tire pressure - Low Trac - etc?
Posted: Nov 05 2004 at 7:08pm | IP Logged
Headlamp chime still works.That's fine.
As for low psi etc. I don't know. If warning lights work and there is no chime I can live with that. Actually I could live without all of it I guess. I have until I got the Titan.
CactusJackSlade Groupie
Posted: Nov 05 2004 at 9:29pm | IP Logged
fox92020 wrote:
Doesn't that also warn you, along with warning lights, of low tire pressure - Low Trac - etc? |
So just let all the air out of one tire and go for a drive - please report back ASAP!
CJS
__________________ CJS
http://www.racemtbikes.com
Posted: Nov 11 2004 at 12:20am | IP Logged
An update of the Tire sensor would be nice as I would like to do this mod...ummm now
Posted: Nov 11 2004 at 7:04am | IP Logged
So unplug the wire and be done with it.
I'm not wasting my time doing tire pressure tests. If you want this information you don't need me.
I'm not busting your chops here. Someone commented on it, I didn't like it either, so I found it and fixed it. That's all I wanted.
Posted: Nov 11 2004 at 10:21am | IP Logged
All we were hoping for is that you fix was perfect as so far it seems to be. Don't be upset, we all love what you are doing.
