Posted: Nov 05 2004 at 4:05pm | IP Logged
Yes,
It is a fairly common problem.
It is a design defect with the a/c drain line that allows some of the water to drain back into the cab and under the carpet on the passenger side.
I fixed mine myself in about 10 minutes with the instructions found on another Titan site. I then carried it into my dealer & showed him what I had done. He said the a/c drain issue was common & that they would have fixed it exactly like I did. Because of some story swapping I have a call into Nissan to find out when the issue will be resolved so it can be fixed professionally.
The way the drain is designed I don't understand how 100% of Titans do not have this problem.
