TSB - Technical Bulletins
 Nissan Titan Forums : Problems / Technical : TSB - Technical Bulletins
Subject Topic: Transmision fluid leak Post ReplyPost New Topic
doh3
U.S. - Mississippi
Posted: Dec 07 2005 at 12:25am | IP Logged Quote doh3
Anybody had problem with the trans. fluid leaking from one of the lines running near the radiotor?............I just had it fixed supposedly but the leak is still there.............Pretty agrivating..............It's hard to even see where it's coming from but it's dripping all over my front skid plate then blowing back all over my shock and steering components.(on the passenger side)
I think i t's trany fluid but it's very dark.  Only once did I see what looked like a red colored oil dripping.  All other fliud levels seem to be fine.
Back to Top View doh3's Profile Search for other posts by doh3
majazawa
Posted: Dec 11 2005 at 6:54pm | IP Logged Quote majazawa
just noticed a huge puddle of fluid under the truck and all over the skid pan. Trans fluid leaking from a fitting screwing into the radiator next to the coolant drain petcock on the passenger side. contacting the dealer tomorrow for repair. trans fluid is really low.
Back to Top View majazawa's Profile Search for other posts by majazawa
doh3
U.S. - Mississippi
Posted: Dec 11 2005 at 9:24pm | IP Logged Quote doh3
Sounds like the same thing I had.  I brought it in to be fixed and after a week they said it was good to go. I just brought it back in this past Friday again, because it is still leaking.  Hopefully they fix it this time.  They added new brake pads also the previous trip because of my complaint of brake judder.  Thanks for the reply.
majazawa
Posted: Dec 14 2005 at 7:23pm | IP Logged Quote majazawa
dealer replaced trans. rubber hose leading to the radiator.  I'll check in a couple of days to see if this really worked.
doh3
U.S. - Mississippi
Posted: Dec 14 2005 at 9:24pm | IP Logged Quote doh3
I just got mine back for the second time.  I did't see any oil on my skid plate this time after driving it home.  The part # for the coollant line they replaced was the same, but there was another part # that wasn't mentioned last time that I'll have to check out.
