Subject Topic: Solid tonneau cover for $110 or less! Post ReplyPost New Topic
CactusJackSlade
Posted: Nov 20 2004 at 3:34am | IP Logged Quote CactusJackSlade
Hey all,
I wanted a fast, cheap way to secure the stuff in my bed... and that UtiliTrack railing is what made it EZ. Here is what I came up with:
I made a very heavy duty cover for the Titan utilizing the rails on the utilitrack system. It is simple. It has 3 interlocking 3/4" plywood panels using aluminum trim channel (back to back) in between. Because it is supported all the way around inside the utilitrack system (except the back) and there are these channels on each pannel, this is a very sturdy rig! Notice the bicycle fork mount I've installed to carry my bikes. I use the rear panel handle to secure the back tire of the bicycle.
Here are some photos:
I also found plastic bins at Home Depot/Lowes that fit underneath perfectly!
The olny rreason it cost my this much is because i used a sheet of interior birch plywood @ $45 for the 4x8 sheet!
CJS
CJS
http://www.racemtbikes.com
silverbullet
Posted: Nov 20 2004 at 8:15pm | IP Logged Quote silverbullet
I am impressed with your engineering.  I have found myself looking at it thinking, "what would I do differently?"  So far, it serves its purpose.  Is it a snug fit or will it slide back and forth?  Again..........good job.
Back to Top View silverbullet's Profile Search for other posts by silverbullet
CactusJackSlade
Posted: Nov 21 2004 at 2:12am | IP Logged Quote CactusJackSlade
Silver Bullet,
As to your Q: It is so snug the tail gate almost does not close!... I had to re-cut the last panel twice... er, a three times to get it just right.
I have not had it on long enough to know what I'd do different yet, but I'm sure some things will crop up.
My first idea was to hinge the panels together, being able to flop one on top of the other... but with 3/4" ply it gets to be a heavy handfull pretty quick, so I made it 3 panels... managable.
One thing I like right off the bat is that it is wood... EZ to mount stuff on... and it was cheap enough so if I screw up I can replace the wood easily enough.
I'll post a "review" after my road trip next week...
CJS...
CJS
silverbullet
Posted: Nov 21 2004 at 10:47am | IP Logged Quote silverbullet
Do you think that the weather might play a factor in the wood expanding or contracting.  Come to think of it, the paint would help out in that.  Look forward to your long term thoughts.
smoke4x4
Posted: Nov 21 2004 at 11:19pm | IP Logged Quote smoke4x4
Hi everyone,
New Titan owner as of yesterday. Love the truck!
I was searching the board looking for different Racks and I see in CactusJackSlade's pictures that he has a roof mounted rack that looks like a Thule. Can anyone please point me to where I can get one f those?  Thanks,
Fred
2005 Titan Crew LE 4x4
Back to Top View smoke4x4's Profile Search for other posts by smoke4x4
smoke4x4
Posted: Nov 21 2004 at 11:27pm | IP Logged Quote smoke4x4
Actually I just found a post about the Yakima track system,  Thanks in advance for any other suggestions.
blue73thing
Posted: Apr 29 2005 at 9:42pm | IP Logged Quote blue73thing
What happened to the pix of CactusJackSlade's fine tonneau.  I was trying to show it to my wife, but the pix don't appear in the post.  Is it my pc, or did they get moved?
04 CC LE 4x4 (delivery 4/05)
Back to Top View blue73thing's Profile Search for other posts by blue73thing
