Subject Topic: Daystar Level kit warning! Post ReplyPost New Topic
Prlauren
U.S. - New York
Posted: Jan 22 2005 at 1:40pm | IP Logged Quote Prlauren
   Daystar kit will cause failure to front struts! Had my struts replaced twice! Until I found this: http://performancelifts.com/cgi-bin/cart/GGNLK4.html
      I found this on www.titantalk.com/forums this kit works and will not blow out stock struts! Daystar's kit causes strut to top out and ruin valving in strut! ask for prerunnergreg and tell him Prlauren from Titantalk.com sent you!
        Any Questions Feel Free to E-mail me Prlauren@optonline.net. I have The PRG kit installed! 2004 Nissan Titan CC off-road package
Back to Top View Prlauren's Profile Search for other posts by Prlauren
RHINO
U.S. - Louisiana
Posted: Jan 22 2005 at 1:54pm | IP Logged Quote RHINO
This kind of stuff is what keeps me from doing this to my truck.  I want to so bad, however this seems to be somewhat common and I am not going to risk it until it is perfected.
TITAN
New Orleans 'The Big Easy'
04 Titan SE KC
Off Road
Radiant Silver
Tinted
Nissan seat covers
more to come.......
Back to Top View RHINO's Profile Search for other posts by RHINO
Prlauren
U.S. - New York
Posted: Jan 22 2005 at 2:35pm | IP Logged Quote Prlauren
       Trust me the PRG kit is the only leveling kit that works! I have it in my truck! I thought I learned my lesson with making mods on my vehicles from all the problems! The Daystar Kit blew out my struts twice until I put the PRG Gagnon motor sport level kit in it does not effect spring rate or strut in anyway! Check out the reviews!!!! I love it!
Johnboy
U.S. - Washington
Posted: Jan 24 2005 at 3:57am | IP Logged Quote Johnboy
Thanks for the heads up! I was about to order the Daystar. What is the difference in the kits that cause the failures?
Johnboy
Johnboy
Back to Top View Johnboy's Profile Search for other posts by Johnboy
Prlauren
U.S. - New York
Posted: Jan 24 2005 at 5:55pm | IP Logged Quote Prlauren
    The daystar kit uses the Strut and shock in the assembly of the kit. The coil spring needs to come off the shock and a spacer goes on the bottom then the coil spring goes back on. Then on top of coil spring another spacer goes on then the OEM plate to hold the assembly together. Which makes the strut (shock) top out to far then it is intended to do. Which causes failure to the shock. The Coil will also be affected with binding! This will give a harsh ride and ruin the Struts.
     The Gagnon level kit works because you take the whole strut assembly out of the truck without taking the strut assembly apart! The oem Strut has three threaded bolts on top of strut. The gagnon level kit has three resessed holes which the stock bolts go inside and the Gagnon spacer sits on top of strut assembly! Then the spacer has it's own threaded studs that bolt back into strut mount. Not affecting the shock or the spring or the stock ride quality that the Daystar kit ruins.
     Check out Performancelifts.com under suspension and it will show you a picture of the Gagnon kit! This kit works! Trust me don't buy the Daystar kit it sucks!
Johnboy
U.S. - Washington
Posted: Jan 24 2005 at 10:03pm | IP Logged Quote Johnboy
Thanks for the detailed information. I had already planned on the gagnon kit, just needed to know why the cheaper setup is not very good. There is one thing i learned in life, that is you get what you pay for.
Thanks again
Johnboy
Johnboy
Prlauren
U.S. - New York
Posted: Jan 25 2005 at 6:39pm | IP Logged Quote Prlauren
     No Prob let me know after you install! Show some pics. You won't be disappointed! Just make sure when you order to specify if you have the Off-road package or not!
Johnboy
U.S. - Washington
Posted: Jan 26 2005 at 2:08pm | IP Logged Quote Johnboy
Yes good point, I do not have the OR package.
Johnboy
Prlauren
U.S. - New York
Posted: Jan 28 2005 at 7:52pm | IP Logged Quote Prlauren
I still would go with Gagnon Level kit! Daystar ruined my struts big time I wish some aftermarket companies would put a little research into the product before selling it!
robert borsa
U.S. - Maryland
Posted: Feb 10 2005 at 5:57pm | IP Logged Quote robert borsa
hi all,
   I was going to put the daystar 2.5 in. lift on the front. could not find it anywhere so i called daystar and they told me to wait for about 6 mounths. becouse they are redesigning it becouse they have had so many of them returned or you can go to another lift go luck all
                                 the big dog
the big dog
Back to Top View robert borsa's Profile Search for other posts by robert borsa
