Subject Topic: Leveling Kit Post ReplyPost New Topic
ti_10
Posted: Jul 13 2005 at 4:11pm | IP Logged Quote ti_10
I found a leveling kit on e-bay, seller is TopGun CustomZ, has anyone installed of these kits and if so are you satisfied with the ride, fit and function?
I own a 2004 LE Crew with 4X4, but not off-road package and want to level it out.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem& ;tc=photo&category=33585&item=7985828041
Back to Top View ti_10's Profile Search for other posts by ti_10
ensclark
Posted: Jul 16 2005 at 1:56pm | IP Logged Quote ensclark
check out nitrousenterprises.com   Thats where I got mine,  love it!!!
4LE,CC,BT,OR,Fullyloaded,Bullbar,NitrousEnterpriseslevel/lif t kit,ARE bedcover,centerline17x8 rims,
Back to Top View ensclark's Profile Search for other posts by ensclark
HavockWK
Posted: Jul 19 2005 at 1:47pm | IP Logged Quote HavockWK
You have to check out Prerunnergreg's (PRG) kits!  PRG's kits are the best available for the Titan.  A 2.5" kit like the Top Gun kit you mentioned is not recommended for a 4x4 Titan without making other modifications because it is will make your front end higher than the rear (a 4x4 is 2" to level) and will also allow the upper arm to clunk on the coil bucket which will require you to grind down your coil bucket or get a longer arm.
PRG's kits also come with new larger bumpstops to help control the compression and help prevent you from destroying your front shocks.
Go here for pics of my install: http://www.tscomputerservices.com/titan/PRGkit.html
Havock
Deep Water Crew Cab SE
Big Tow -- Utility Bed -- Off-Road
Born 01/04
PRG 2.5" Front/1.5" Rear Lift
Havock's Titan Page
Back to Top View HavockWK's Profile Search for other posts by HavockWK Visit HavockWK's Homepage
