| Posted: Jan 25 2006 at 7:41pm | IP Logged
Recieved it and installed it. I can tell you it is VERY loud inside under heavy throttle, but I like it! I can feel a slight power increase (seat of the pants feel anyway).
I don't know how bad the other manufacturers are to install, but this was a major pain in the butt! I've installed 2 K&N's in other vehicles which probably makes a huge difference, and they were a snap.
I knew it'd be a pain when one of the 1st directions read "remove left front tire". Worth it? Sure! Less expensive than some others, sounds good, rated good for HP gains, etc.
