Posted: Mar 10 2006 at 3:55pm | IP Logged
the term big block has never been so over used in a single thread
"The Titan CORR Pro-2 entry features a 715-horsepower, 5.6-liter V8 stock block engine with 510 lb-ft of torque at 6,000 rpm, redlining at 8,200 rpm. Unlike many race engines, the block, cylinder heads, cam covers, water pump, main bearings, rod bearings, and ignition coils are all stock Titan components. The engine was prepared by Menards Engine Development."
with that kind of power on tap I doubt there is a need for a second totally different (read more expensive to engineer) engine
