Posted: Jun 28 2004 at 11:55am | IP Logged
I just installed a pair of chrome step bars (last Friday) and struggled with the removal of 2 of the mounting bolts to the frame. I did not use WD40, which I should have. Two bolts came out with the thread stripped off. These bolts are 4"+ in length. I could not explain to myself as to how I could have stripped off about 1/2" of threads, unless (1) it was cross-threaded at installation of the bolts or (2) it was loctited . But the other 2 came out cleanly. I installed and re-torqued the bolts back in using the remainder threads still good on the rest of the bolts. I hope they will hold. I took the truck up Santa Cruz mountain with kids jumping up and down on the bars, and so far they hold up still.
Does anyone have any explanation how the bolts could have threads stripped? and how can I fix this to prevent the bars from dropping onto the ground one of these days?
I have a couple of photos, but can't seem to add to the post. Any idea how?
Thanks much.
__________________ Mytruck04
