Subject Topic: IAT sensor Post ReplyPost New Topic
h46crewchf
Posted: Aug 20 2006 at 9:30pm | IP Logged Quote h46crewchf
Has anyone bought the resistor that tells the ECU that you are running a cold air intake when it is actually stock? (EBay) Also, where is the IAT sensor? Any experience with anything like this???
2006 TITAN KC SE 4x2 Granite. 22" shoes, UNGO RS 6000 remote start w/auto UP&down windows, Fram Boost 2, Flowmaster 40, Sirius Sportster, Ram Mount for Comp w/AIRCARD & GPS, 5% tint all around.
Back to Top View h46crewchf's Profile Search for other posts by h46crewchf
miserytom
Posted: Aug 21 2006 at 2:26pm | IP Logged Quote miserytom
um, you must be joking if you actually belive that ebay thing bud, if so, im sorry to tell you, that its a huge load of B/S lol
h46crewchf
Posted: Aug 21 2006 at 10:24pm | IP Logged Quote h46crewchf
A better response would be that the Mass Airflow sensor AND the IAT sensor share the same connector. (I learned that important piece of info a little late...) SO, it wouldn't work on the TITAN even if it really did work. Fortunantly, it was only like 6 bucks... Do you have a cold air induction kit Tom? better MPG??? better HP??? which brand do you recommend? also the same for exhaust??? Thanks, Rusty
miserytom
Posted: Aug 22 2006 at 5:01pm | IP Logged Quote miserytom
well, i have a home made version, i cut the intake tube off of the airbox, and put on an AEM filter with a 3.5 inch inlet, better power yes, the MPG i dont know, and honestly i dont really care about the MPG, i didnt buy a 5500 lbs V8 truck for good MPG lol, plus, i have a very heavy foot, so having good MPG is way out the window for me lol, personally i reccommend the AEM, mainly because it's an oil -less filter, after sending in a few oil tests to blackstone labs, using a K&N filter i saw high levels of silicone in my oil, most likely due to the oil in the K&N filter, the AEM is basically the same type of cleanable filter without the oil...
