Subject Topic: bug deflector? Post ReplyPost New Topic
6thsense
U.S. - Virginia
Posted: Oct 01 2004 at 10:58pm | IP Logged Quote 6thsense
does anyone know if the stock bug deflector requires any drilling??
CactusJackSlade
Posted: Oct 01 2004 at 11:10pm | IP Logged Quote CactusJackSlade
Mine has no drilling that I can see, it looks to clip on.
CJS
CJS
http://www.racemtbikes.com
Der sheist
U.S. - Arizona
Posted: Oct 04 2004 at 11:04pm | IP Logged Quote Der sheist
I bought one and installed it; no drilling required.  Two clips get snapped into holes under the hood, some placement of clear scratch-prevention stickers on the hood where the bug-gaurd contacts the paint and that's pretty much it.
After about 700 miles, I decided I didn't like it anymore, so I took it off; there is no indication that I ever had one.  Overall pretty easy install.
2006 Titan LE CC 4X2
Smoke
Back to Top View Der sheist's Profile Search for other posts by Der sheist
WheelinJeeper
Posted: Oct 14 2004 at 9:41pm | IP Logged Quote WheelinJeeper
what color did you have? do you want to sell it? and what condition is it in?
Back to Top View WheelinJeeper's Profile Search for other posts by WheelinJeeper
Der sheist
U.S. - Arizona
Posted: Oct 15 2004 at 3:38am | IP Logged Quote Der sheist
The bug deflector is just standard smoke black/somewhat see through plastic.  It is good quality, being made by Nissan and all, and mine is still in good condition; however, all the mount brackets I threw away, and there are 3M stickers needed to prevent scratches on the paint for installation.  Needless to say, I can't really sell mine except to someone that already has one installed and needs to replace the deflector itself and has the mounting brackets already.  I don't know if you can just order the mounting brackets/kit through Nissan, but it's worth an inquiry.  If you find out, I can sell this dirt cheap.
Smoke
