Subject Topic: Leveling the rear gap Post ReplyPost New Topic
thaimonkee
U.S. - Maryland
Posted: May 12 2005 at 5:37pm | IP Logged Quote thaimonkee
I have a 2004 titan with big tow package. the rear wheel has a huge gap. i know its a truck but still i want to lower the rear end alittle to even out with the front. what is recomended for this?. any help would be great,.
Back to Top View thaimonkee's Profile Search for other posts by thaimonkee
Mavryck
Posted: May 12 2005 at 7:29pm | IP Logged Quote Mavryck
Tow something heavy
Mavryck
Back to Top View Mavryck's Profile Search for other posts by Mavryck
jun3462
U.S. - Alaska
Posted: May 13 2005 at 5:04am | IP Logged Quote jun3462
same here thaimonkee.  i just installed 22s with nittos 285/45 and the wheelwell is more exposed.  heard you can get drop shackles and will drop about 2 inches on the back.  i will research more and let you know.
Back to Top View jun3462's Profile Search for other posts by jun3462
thaimonkee
U.S. - Maryland
Posted: May 13 2005 at 6:00am | IP Logged Quote thaimonkee
thanks. im pretty sure somewhere sells like a 2 inch drop for the rear somewhere.
there another guy,m95roadster, he said to de-arch the leaf springs. but i have no idea what that means
ensclark
Posted: May 13 2005 at 6:56am | IP Logged Quote ensclark
If you put on the helper springs on the front. It will work as a traction bar and drop it some where between .5 and 1 inch.  I'm sure you are all looking for more than that but it may help.  It's amazing what a inch looks likes
4LE,CC,BT,OR,Fullyloaded,Bullbar,NitrousEnterpriseslevel/lif t kit,ARE bedcover,centerline17x8 rims,
Back to Top View ensclark's Profile Search for other posts by ensclark
m95roadster
Posted: May 13 2005 at 1:57pm | IP Logged Quote m95roadster
De-arching the spring is basically reshaping it to any height you choose. A suspension shop can do this for you. The spring rate remains the same as stock.
2005 SE CC Smoke
Flowmaster American Thunder Exhaust - click here
Back to Top View m95roadster's Profile Search for other posts by m95roadster
m95roadster
Posted: May 13 2005 at 2:00pm | IP Logged Quote m95roadster
There is no room under the bed for a 2" shackle drop. To even get to 1 1/2" you would need to grind the bed somewhat.
2005 SE CC Smoke
thaimonkee
U.S. - Maryland
Posted: May 13 2005 at 3:33pm | IP Logged Quote thaimonkee
i called streetbeat customs and they have 2x4 inch drop  but thats alitle too much for what im looking for. i just want the rear to be even with the fronmt. and there kit cost 800 shipped which is too much for me right now.  i ask most shops around here to see if they do that dearching and no ones does it. not yet at least.
m95 roadster. how many inch drop or whatever they call it did you do when you dearched your leaf's?
m95roadster
Posted: May 13 2005 at 3:56pm | IP Logged Quote m95roadster
Call 4x4 shops. They'll know. I had mine dropped 2 1/2" rear and the front is 1".
I had the kit you were talking about and it sucked bad. Worst ride ever! The drop was more like 4 1/2" rear and 1" front. The back sat a lot lower than the front.
2005 SE CC Smoke
Kevante
U.S. - Arizona
Posted: May 13 2005 at 9:10pm | IP Logged Quote Kevante
I want to level the rear also but not sure how to do it without cutting or huge dollars.
CC LE Galaxy Black
