Subject Topic: Westin Bull Bar Post ReplyPost New Topic
teejake
Posted: Sep 04 2005 at 2:28pm | IP Logged Quote teejake
Anyone found a way to modify the factory off road skid plate to work with a Westin Bull Bar?
Back to Top View teejake's Profile Search for other posts by teejake
ensclark
Posted: Sep 07 2005 at 5:19pm | IP Logged Quote ensclark
Yea,, I cut a U shape right where the bar goes and it fits great,  You realy can't see the cut unless you get down on it.
4LE,CC,BT,OR,Fullyloaded,Bullbar,NitrousEnterpriseslevel/lif t kit,ARE bedcover,centerline17x8 rims,
Back to Top View ensclark's Profile Search for other posts by ensclark
teejake
Posted: Sep 08 2005 at 10:32am | IP Logged Quote teejake
I really appreciate the help (and the photos). Did you have to modify the front brackets that the skid plate and the factroy tow hooks attach to? I could not see how to get the brakets mounted along with the Bull bar so for now it is mounted direct and I left the brackets and the skid plate off.
ensclark
Posted: Sep 08 2005 at 4:02pm | IP Logged Quote ensclark
The instructions came with mine.  you put the bull bar in the spot the hooks went.  There should have been a spacer, looks like a small piece of pipe, that goes over the bracket for the skid plate.  It just bolts right back into place.  You will have to play with it and get the bolts lined up before tighting it.
