Subject Topic: Trailer Lights Post ReplyPost New Topic
LATitan1
Posted: Dec 23 2005 at 6:18pm | IP Logged Quote LATitan1
I have a problem with trailer lights.  My lights on the right side of the treailer do not work.  So I hooked up connector to a tester and I am not getting a signal from the truck to operate the right blinker.  I did not get the towing package when I bought the truck but installed a factory towing package and put both relays in under the hood.  Anyone have any suggestions I would be very appreciative.
Back to Top View LATitan1's Profile Search for other posts by LATitan1
LATitan1
Posted: Dec 24 2005 at 4:57pm | IP Logged Quote LATitan1
Anyone have any suggestions??????
Titan Power
U.S. - Indiana
Posted: Dec 28 2005 at 10:29pm | IP Logged Quote Titan Power
You might check with the dealer, there is a recall on all the 05' for the towing pre-wiring.
Titan power
Back to Top View Titan Power's Profile Search for other posts by Titan Power Visit Titan Power's Homepage
LATitan1
Posted: Dec 29 2005 at 8:46pm | IP Logged Quote LATitan1
Well I figured it out with a little troulbe shooting I figured out that the 2006 has seperate relays for the left and right turn signals, called my dealer service department and they were not aware of this but are ordering me the other relay.  Hope this saves some others some trouble.  So in summary you need 3 relays for 2006 models.  2 turn signal relays and a tow power relay.
miserytom
Posted: Jan 31 2006 at 7:12am | IP Logged Quote miserytom
the recall is actually on the Body Control Module, all the recall really does is replaces the BCM wiring harness, only differance is nissan added 2 fuses in the harness for the trailer lighting circuts
