Posted: Oct 01 2006 at 3:31pm | IP Logged
UPDATE: Unorthodox Racing has informed me that the production of the underdrive pulley will be set back due to design issues and balancing problems with their original solid prototype.
The original prototype was a lightweight, smaller in diameter, solid aluminum pulley. This design has been superb in many vehicles since most modern vehicles especially those of which have high end engines are well designed and balanced to have minimal to no harmonic resonation throughout the rev range.
Since the TITAN was not designed for racing or high performance, the internals of the 5.6L V8 are not balanced enough to reliably have a non dampened pulley on the engine, so UR is designing a new underdriven harmonic balancer that will be slightly heavier than the original prototype, but still significantly lighter than the stock pulley, and smaller in diameter to "underdrive" the accessory/fan belts to release power from the engine while still keeping the electrical charging system from being compromised.
On that note, I just received an e-mail from ASP racing, saying that they have dumped their underdrive dampener project due to them not wanting customers to deal with the radiator removal to install the pulley. Their loss.
__________________ "My other ride has TwinTurbos"
