Subject Topic: Suspension sounds??? Post ReplyPost New Topic
miTITAN04
Posted: Jun 23 2004 at 8:52am | IP Logged Quote miTITAN04
Not sure if this is normal or not.  So I thought that since I have not read any threads regarding this I will bring it up.
When driving into & out of a deep-short trench, I hear a loud "klunk" then a "klank" as if the suspension is bottoming-out.  This occurrs both in front and in back.  Speed is slow to moderate.
I am also not sure how the suspension is setup.  Dual-stage or something of the like.  I know it is a multi-leaf in the rear.
Lastly to note, it appears the leafs in the rear spring have an unusual gap between layers.
I'm new to full-size trucks, so bear with any non-knowledge that I may have expressed.
Please let me know if anybody else are expeiencing similar sounds.
Phil E
Back to Top View miTITAN04's Profile Search for other posts by miTITAN04
ryanehill
Posted: Jun 29 2004 at 7:15pm | IP Logged Quote ryanehill
Yeah I noticed that yesterday when I took it up to the Rocky Mtn. National park on bad dirt roads with huge potholes. I have a 2" lift on it and the front really slams hard on the down side of any bump or even speed bump.
Back to Top View ryanehill's Profile Search for other posts by ryanehill
WPBTitan
Posted: Jun 30 2004 at 7:37am | IP Logged Quote WPBTitan
I had an F150 4X4 that did the same thing.  It usually occured when running over unlevel ground with one wheel up and the other bottomed out in rut.
Back to Top View WPBTitan's Profile Search for other posts by WPBTitan
