Posted: Jan 22 2005 at 11:47pm | IP Logged
Actually,
If you get the Nissan OEM XM radio you can switch to XM by using the RADIO button just as you mentioned. I have found that if you go to several places online to order them you can find them for $240 if you put the part number in directly. Watch out for shipping (I would call them) some charge a flat % of total order for shipping some as high as 25%. It seems that they charge different prices for different vehicles for the EXACT same part number so that is why putting in the part number manually gets the lowest price.
You will need:
XM Tuner: Part number 999U9-NV003
XM Antenna: Part number 999U9-VQ011
I am not so sure about the bracket, some peoples say yes, others say no. One dealer I talked to said if I had the Rockford Fosgate CD-6 changer unit I didn't need the bracket. It DOES appear to me that there is a place it could be mounted under the driver side dash close to the N-Bus connector (that it connects to). I still need to get mine and install it, I just got my Titan 1 1/2 weeks ago so I am figuring it all out as well.
Go to one of these sites:
http://www.trademotion.com/partlocator/index.cfm?siteid=55&a mp;catalogid=0
http://www.buynissanparts.com/storefront.htm
Put int the part numbers I gave you on the direct entry field and you will see the price and can add it to your cart. I think buynissanparts.com charges a flat 15% shipping rate and not sure about EverythingNissan.com but I called them the other day and they confirmed they could ship it to me for $270 total for the tuner only. You may want to have it professionally installed if you are not familier with the hook up and running cables, including removing interior parts and components to get to the necessary locations and connections.
Hope that helps,
__________________ Tight'un
'04 SE CC, BIG Tow, Bed Pkg, Fosgate, all stock... FOR NOW!
