Clayton Newbie
Posted: Mar 19 2005 at 12:45pm | IP Logged
Hi. I'm a new Titan owner. I'm originally a sports-car guy
(04' RX-8) but this bad boy has brought me around to the dark
side! (black titan 4x4 SE) When I got is last week I had a
really hard time finding just what I wanted from the dealer and like
most had to compromise. Which brings me to my question: I
really wanted the Rockford Fosgate stereo but had to settle for the
6disk changer. Which is still pretty good. But I can't
find ANY info on what the standard 6 disk changer is? How does it
really compare spec wise with the upgraded package? I'm told it's
made in the same plant with the Fosgate which isn't actually a fosgate
but a panasonic or clarion or something like that?
So is the standard 6-disk changer a Panasonic? Also from what I
can tell the fosgate package has an extra center speaker in the dash
and a sub woofer under the drivers seat? And the rest of the
speakers are different between packages?
(Now let's keep in mind I know very little about car audio)
Is the wiring harness the same for all the stereo's so the Rockford
Fosgate can be plugged in without any modifications? Would it
make a difference without adding the sub and the amp. From what
I've read in other posts it might be as good to just upgrade the
speakers?
Any input would be appreciated. And finally I'd like to thank the
members of this forum as it was incredibly helpful in my decision to
buy a Titan.
thanks,
Johnathn Clayton
Des Moines, Ia
Venomous Newbie
Posted: Mar 19 2005 at 2:35pm | IP Logged
If you read my post titled installed new audio system, I went into a little detail about what I found in the rockford system.
My guess is that your 6 disc changer is the same Panasonic unit used in the Rockford system.
Clayton Newbie
Posted: Mar 19 2005 at 10:29pm | IP Logged
Thanks for your reply. I did read your post and every other one
pertaining to the Rockford Fosgate upgrade but nothing really explains
the difference. Seems to be as much of a mystery as why they
advertise it as a "Rockford Fosgate" stereo. Your guess that it's
the same head unit is also my guess, I was just hoping to confirm
it. At this point I'm thinking it's fine the way it is and maybe
my money is better spent getting the XM radio option.
Frost Newbie
Posted: Sep 13 2005 at 10:39pm | IP Logged
yes i can confirm they are the same exact head unit
the only reason they call it rockford fosgate is cause it has a rockford amp under the driver side dash even the speakers are the same, exept for the sub and the center speaker wich the other one dont have
Posted: Sep 13 2005 at 11:07pm | IP Logged
This makes me feel cheated. You pick out the RF system because you know it's just gonna kick ass then after some research you find out that only 1 item in the whole system is actually Rockford Fosgate. What a screw over! But, in it's defense, it does rock harder than standard stock equipment, and I actually can out perform some kids "custom" systems.
Posted: Sep 14 2005 at 10:13pm | IP Logged
Ive heard the RF system in a friend's Titan, and it ain't bad. But if you have already purchased the truck w/o it, I would recommend replacing the factory speakers with some decent aftermarket ones. You shouldnt have to spend a bundle either; some mid-range priced Sony or Kenwoods will make a dramatic improvement to your audio system. (I prefer Polk Audio). Also, add a powered sub for a little low-end umph. Or if you want to really go nuts, add a quality 5 channel amp, and a couple of 10's under the back seat. Remember, you can spend as little or as much as you want on audio eqpt. My point is to get the most bang for your buck. IMO, replacing the factory speakers, and adding a powered sub will suffice....keep on truckin
