McClendons Newbie
Posted: Jun 11 2005 at 9:50am | IP Logged
All,
I know speaker size has been talked in several threads, but often it
was for the RF systems. I have a 2005 Titan SE, base radio and
want to change speakers. Can someone confirm that the fronts are
inded 6x9 (with no cutting required) and the rears are 6.5".
Also, are there any drpth issues.
From the board, I was pretty comfortable, then found that best buy, circuit city and ultimate all show 6.5" for the fronts.
Thanks in advance
Nihlism Newbie
Posted: Jun 11 2005 at 11:16am | IP Logged
fronts are 6x9 but rears ar closer to 7in you can get adaptors or just
buy 6.75in speakers and drill new holes. no depth issues with in reason
an average 6x9 fits no problem
Posted: Jun 11 2005 at 11:18am | IP Logged
I noticed that on Crutchfield.com that they give depth and size on speakers that will fit YOUR Titan, if you click on "WHAT FIT'S MY CAR?" link, you will be able to put in the info of your specific model. Hope that this may help.
Posted: Jun 12 2005 at 10:19pm | IP Logged
pied_piper wrote:
I noticed that on Crutchfield.com that they give depth and size on speakers that will fit YOUR Titan, if you click on "WHAT FIT'S MY CAR?" link, you will be able to put in the info of your specific model. Hope that this may help. |
Ditto...plus they will supply you with adapters so you can use 6.5" if you want, which is nice cuz that greatly increases your available options...keep on truckin
McClendons Newbie
Posted: Jun 13 2005 at 6:04am | IP Logged
Thanks for the sizes...no idea why several electronics stores were
saying 6.5" in the front. I found a very good description of door
panel removal for the fronts, does anyone know where the screws are on
the rear doors (for a King Cab vice crew)?
Todd TCE Senior Member
Posted: Mar 09 2006 at 7:34am | IP Logged
Where did you get the panel removal info from? I need to pull the drivers side to do the mirror and it looks a bit more difficult than I had expectd. I hoped to be able to get at the wiring for the mirror simply from the top switch cover but that's not going to work...now I need to pull the panel.
miserytom Senior Member
Posted: Mar 09 2006 at 11:26am | IP Logged
the rear speakers are actually not 7", the speaker itself is smaller, but there molded into the nissan mount, its all one plastic piece, heres a pic of the factory speakers
Posted: Mar 09 2006 at 11:32am | IP Logged
Todd TCE wrote:
Where did you get the panel removal info from? I need to pull the drivers side to do the mirror and it looks a bit more difficult than I had expectd. I hoped to be able to get at the wiring for the mirror simply from the top switch cover but that's not going to work...now I need to pull the panel. |
heres the front door diagram,
Posted: Mar 09 2006 at 11:33am | IP Logged
heres the rest
Posted: Mar 09 2006 at 11:35am | IP Logged
McClendons wrote:
Thanks for the sizes...no idea why several electronics stores were saying 6.5" in the front. I found a very good description of door panel removal for the fronts, does anyone know where the screws are on the rear doors (for a King Cab vice crew)?
this is because there are brakets so u can put in a 6.5 in the front if u want
