Posted: Mar 01 2004 at 9:34am | IP Logged
Gentlemen,
Over the weekend, I pulled the faceplate off my radio in order to gain access to the aux power plug wiring (cigarette plug). The cover plate was easy enough to remove, but be prepared to disconnect about 8 electrical plugs (no big deal, but a bit overwhelming). I spliced into the right side cigarette plug as it is connected thru the ignition switch. I now have my portable (Roady) XM unit as well as my radar detector hardwired, so no more cords going every which way.
My primary reason for writing is to inform all Titan owners that once you remove the radio face plate, it will take a trip to the dealership to get the airbag light extinguished. Mine started blinking once I completed the above installation. At first, I thought I may have jostled some of the airbag wiring, but when I spoke with a Nissan rep at the dealership, he informed me that anytime you remove the radio/airconditioning faceplate, the airbag light will illuminate. I asked him if I could turn it off myself, but the service guy said it has to be done with a computer they have at the dealership. I'm headed to the dealership later today, so I'll let you know if any problem should arise.
Chad
