Titan Towing / Hauling
 Nissan Titan Forums : Titan Towing / Hauling
Subject Topic: uhaul towing light hook up Post ReplyPost New Topic
mnealp33
Posted: Jan 12 2005 at 9:25am | IP Logged Quote mnealp33
I know i shouldn't have taken it to them in the first place but oh well, for some reason my trailer lights that they hooked up for me only work intermitenly.  The problem is a bad ground conection trough my hitch receiver for some reason it doesn't ground itself right.  Anyone else had a problem like this?
Back to Top View mnealp33's Profile Search for other posts by mnealp33
IQ9*
Posted: Jan 12 2005 at 4:46pm | IP Logged Quote IQ9*
Uhaul jacked my suburban up when the did a harness for me. I kept blowing the fuse on the brake lights They still state it was done right BUT they would look at it again and magically the issue disappeared.  I don;t know why it takes them 2 tries to get it right.
mnealp33
Posted: Jan 13 2005 at 5:49am | IP Logged Quote mnealp33
i ussually do stuff like this myself but i let someone talk me into it ,
Does anyone know if they have came out with the plug and play harness for it yet
Red Brawn XE
maddog
Posted: Feb 10 2005 at 2:03am | IP Logged Quote maddog
If you go to Kragen or your local auto parts store, they should carry the necessary plug. Look under your driver side tail light, there should be a can type plug. It's taped to some wires behind the rear bumper. Pull the cap off and plug in a seven prong (I could be wrong on the seven prong) chevy plug (for sure a chevy plug). If you aren't sure, most autopart stores will let you bring the part out to the parking lot and check. Just leave a credit card and they're cool with it until you actually buy the part.. I it takes all of 5 minutes for the total install. Get the mounting bracket and mount it to your receiver.
I put a six/four prong plug outlet so I don't have to put an adapter for my boat. My boat uses the standard four prong flat bar plug. If I need a circular six prong for whatever I'm towing, its there.
Smoke XE 4x4 Crew Cab, Prefered pkg, Leer Tonneau, Line-X Spry-on, Hidden Hitch Class III tow.
Back to Top View maddog's Profile Search for other posts by maddog
mnealp33
Posted: Feb 15 2005 at 8:01am | IP Logged Quote mnealp33
the problem i have around here is that none of the parts stores have anything for the Titan yet and most of them can't even order the stuff yet, Hell i've been trying to get vent visors for it and they can't even get those yet
Red Brawn XE
