Subject Topic: EXHAUST NOISE Post ReplyPost New Topic
stesic
Posted: Nov 19 2004 at 5:10pm | IP Logged Quote stesic
Have been hearing a "ping" noise from underneath the truck when I Idle and more when I turn the vehicle off. Just got under to investigae and felt the "ping" vibration in the exhsust pipe that crosses from one side of the truck to the other. Close to the joint. It seems like there is a heat shield wrapped tight to the exhaust pipe. Maybe the exhaust pipe and heat shield are expanding and contracting at different rates? I don't know, All I know is that it is very annoying to hear and worse when I only made 1 payment. Does anyone have any suggestions??
04 SE King CabAngry
Back to Top View stesic's Profile Search for other posts by stesic
loufish
Posted: Nov 20 2004 at 9:51am | IP Logged Quote loufish
It sounds like the exhaust sys expanding, and contracting as it cools down. My Ford Ranger would do it every time you shut it off if the truck was up to temp. Common among other vehicles also.
Silver KC 2wd
U/T, R/F, Big Tow
Burbank, CA
Back to Top View loufish's Profile Search for other posts by loufish
