Subject Topic: Temp gauge tracking with tachometer Post ReplyPost New Topic
Rocket67
Posted: Dec 08 2004 at 10:11am | IP Logged Quote Rocket67
I noticed a couple of mornings ago that my temp gauge is moving with my tachometer especially when the engine is cold. When I start the motor it goes a bit over mid-way. When I accelerate it pegs at the hot side and when the engine shifts it goes down with engine RPM. Once the engine heats up a bit it doesn't do it as bad but will still do it. If I put the truck in neutral it does the exact same thing. It sounds like the circuit board on the back of the gauge panel has a short but I don't know for sure and would hate to have that pulled out and replaced with only 300 miles on the truck.
-Scott
'04 Titan SE
Back to Top View Rocket67's Profile Search for other posts by Rocket67 Visit Rocket67's Homepage
Rocket67
Posted: Dec 08 2004 at 11:14am | IP Logged Quote Rocket67
Had a suggestion from another forum to make sure it's not the oil pressure gauge......I'll get back on this one.  Not used to so many gauges in the dash.
-Scott
'04 Titan SE
