Subject Topic: air blows while "off" Post ReplyPost New Topic
The Engineer
Posted: Dec 08 2004 at 8:49pm | IP Logged Quote The Engineer
anyone else still get air from outside through the vents when the air is set to "0"?
It seems like the vent isn't closing all the way on mine so I still get fresh air in the cab when its off. Even if its set to MAX AC and Recirculate before I turn it to off.
2004 Titan SE Kingcab
-Smoke Gray
-Big Tow Package
Back to Top View The Engineer's Profile Search for other posts by The Engineer
Posted: Dec 09 2004 at 11:49am | IP Logged Quote thepuffman
If you have the fan on "0" and Recirculate is on, you still have air comin in the vents?  I had a problem with the AC not turning off a couple of times, but if my fan is off and I've got recirculate ON I have never noticed any drafts from the vents...GL
koncept
Posted: Dec 09 2004 at 7:26pm | IP Logged Quote koncept
he means when its sucking air from the outside instead of recirculating
and yeah mine blows a small amount of air (bairly noticable unelss u put your hand to the vent) when the dial is at 0
Back to Top View koncept's Profile Search for other posts by koncept
The Engineer
Posted: Dec 09 2004 at 10:13pm | IP Logged Quote The Engineer
you got it koncept, it doesn't matter what my AC was set to before I turn it off, it defaults to letting air in from the outside when its off. Of course it gets worse depending on how fast I am going, for obvious reasons.
Its almost like the vents arent closing all the way when shut off. Oh well, I have a dealer trip coming soon, I will have it looked at.
-Smoke Gray
-Big Tow Package
Posted: Dec 09 2004 at 10:56pm | IP Logged Quote thepuffman
Exactly...if the fan is off and the vent is set for fresh outside air, ofcourse youre gonna get some air if the truck is in motion. Every auto Ive ever had was like that.
