04GalaxyLE Newbie
Online Status: Offline Posts: 30
Posted: Mar 01 2005 at 11:40am | IP Logged
Wanted to see if anyone here would happen to have access to the service
book with the instructions on installing the Nissan tow hitch and
wiring harness. I think the dealer might give it to me but in the
case they won't...... Thanks.
__________________ 04 LE King Cab "Galaxy", Vent Visors, Bug Sheild, Tint, CDT CL-61 front speakers, Alpine 1629 Rear, Chrome QX56 wheels
'04 off road Groupie
Online Status: Offline Posts: 58
Posted: Mar 01 2005 at 5:53pm | IP Logged
if you buy a nissan hitch it comes with instructions and everything looks clean and factory it also comes with the necessary relays
jmacougar Groupie
Posted: Mar 02 2005 at 9:55pm | IP Logged
I bought/installed the tow hitch a couple of weeks ago. It had to be the smoothest install I've ever done to a vehicle. The hitch comes with four screws which require 101 lb/ft of torque. The wiring harness is actually already on your truck. It's mounted up inside the bumber with a plastic tab. Took me about 15 minutes. Probably would have been faster if I had someone to hold the hitch while I started screwing in the bolts.
04GalaxyLE Newbie
Posted: Mar 03 2005 at 8:57am | IP Logged
Thanks for the insight jmacougar.
Fishy4tU Newbie
Posted: Mar 04 2005 at 1:37am | IP Logged
Where did you guys get your OE hitch and how much did it cost? My titan
didn't have the big tow package but now i want the hitch that comes
with it. What would be the max towing if I installed it myself? Thanks
04GalaxyLE Newbie
Posted: Mar 04 2005 at 7:18am | IP Logged
Bought mine new on ebay for $200 for the hitch &
harness. The dealers charge $230 for the hitch & $125 for the
harness.
Posted: Mar 05 2005 at 4:08pm | IP Logged
i bought mine at nissan for 229 your truck is already wired they also give you 2 relays with the kit at no extra charge
jmacougar Groupie
Posted: Mar 05 2005 at 5:10pm | IP Logged
I bought mine for $199 at the dealership and didn't have to buy a harness.
I would imagine that you would still only be able to tow 7500 lbs. because you don't have the BT gears.
04GalaxyLE Newbie
Posted: Mar 14 2005 at 3:50pm | IP Logged
Installed it yesterday. Was straightforward and took all of fifteen minutes.
