Subject Topic: Seat Belts Post ReplyPost New Topic
crundell
Posted: May 10 2004 at 9:06am | IP Logged Quote crundell
I drive my Titan about 10 hrs per weekend and I've begun to notice something that really drives me crazy about the seatbelts.  The longer I drive, they seem to get tighter and tighter around my waist.  I find myself holding slack in the belt in order to reduce the increasing pressure problem.  Anyone else experiencing this problem?  I inspected the metal buckle and it appears that the problem might have something to do with the ease in which the belt is able to slide thru the loop.  It needs something to introduce a bit of friction where the belt slides thru the loop on the metal buckle.  I also noticed that there is two small holes in the plastic part of the metal buckle which appears to be screw holes.  I'm thinking that this might be the intended mounting points for some type of friction device to eliminate the above described problem.  Can you guys confirm whether your belts have anything mounted on the metal buckle that my truck may be missing?
Back to Top View crundell's Profile Search for other posts by crundell
PJY04
Posted: May 21 2004 at 2:17am | IP Logged Quote PJY04
same problem... rear seatbelt doesn't even let loose... All seat belts are firm...
Nissan Titan LE 2x4 Crew Cab
http://www.phillipyang.com
Back to Top View PJY04's Profile Search for other posts by PJY04 Visit PJY04's Homepage
