Subject Topic: Low Tire Pressure Light Post ReplyPost New Topic
JSTARSPILOT
Posted: May 17 2004 at 7:41pm | IP Logged Quote JSTARSPILOT
On my first Highway trip this low tire pressure warning light illuminated.  It came on around 80 MPH .  I stopped and checked the tires and they all had 36 PSI.  Note that I have installed 20" Goodyears.  I am not sure how the system even works.  I increased the pressure to 40 PSI (44 PSI is the MAX) for the drive home and the light came on again...but only at high speeds.  When I turn the truck off at the gas station and start it back up again the light is out...but once I start down the freeway the light comes on.  Anyone got any ideas?
2004 Black Crew Cab LE
Back to Top View JSTARSPILOT's Profile Search for other posts by JSTARSPILOT
MSAI
Posted: May 17 2004 at 10:33pm | IP Logged Quote MSAI
I was told by the dealer when I bought mine that the system works by means of transmitters located in the stems of the wheels.  (The valve stems).
They said that another Titan with a tire problem could transmit to yours if it is in close proximity!
More likely, you have a bad transmitter and it is loosing it's signal when you get up to high speed.
ms
Back to Top View MSAI's Profile Search for other posts by MSAI
NISSANONE
Posted: May 18 2004 at 12:40pm | IP Logged Quote NISSANONE
YOU NEED TO TAKE IT TO THE DEALER AND LET THEM SCAN IT...TO SEE WHICH WHEEL OR WHAT THE PROBLEM IS
04 TITAN SE...HEMI EATER
Back to Top View NISSANONE's Profile Search for other posts by NISSANONE
