Subject Topic: TPWS Light comes on after 20 min. Post ReplyPost New Topic
Volocty
Posted: Feb 21 2006 at 4:13pm | IP Logged Quote Volocty
Anyone else experience their LTPWS Light (Low Tire Pressure Warning System) come on after about 20 minutes of highway driving?  Any long drive of more than 20-30 minutes (highway / freeway) and the Low Tire light comes on, and stays on until you shut the truck off. Doesn't seem to be Temp related.
Back to Top View Volocty's Profile Search for other posts by Volocty
chokoy
Posted: Feb 21 2006 at 4:38pm | IP Logged Quote chokoy
do check ur tires. it might be a broken sensor or low tire pressure. if ur mileage drops then it is caused by low pressure.
bigbear05
Posted: Feb 22 2006 at 7:32am | IP Logged Quote bigbear05
If your tires or tire is low you may have the leaky valve stem. I think there is a TSB out on it. Here's a link:
http://www.nissanhelp.com/Ownership/Bulletins/Nissan/2004/NT B04-038.htm
May want to take it to the dealer and have them take a look at it. May be a bad sensor.
pied_piper
Posted: Feb 24 2006 at 8:50am | IP Logged Quote pied_piper
These sensors are like the crying baby at a restaurant: NUISANCE. But they can be easily fixed my checking tire pressure, and maybe going about 45lbs in the tires. I myself replaced the tire sensors with regular valve stems. No problems.
electricjohn
Posted: Feb 24 2006 at 1:34pm | IP Logged Quote electricjohn
I am using my spare in the tire rotation scheme, and that causes my light to come on, but it takes more like an hour.
white 4x4 SE CC with big tow,pop w/capts, bed package,splash guards,and floor mats.
born on date 4/1/04
Back to Top View electricjohn's Profile Search for other posts by electricjohn
Clayton
U.S. - Iowa
Posted: Feb 27 2006 at 11:19pm | IP Logged Quote Clayton
Mine do exactly what you're describing.  But only when the temp's below 20 or so.  The tire's are all at 40psi so I know that's not the problem.  I just figured it's a quirk in the system.  My wife's Murano does the exact same thing.  What kills me is that she had a tire with a nail in it and only 18psi and the light didn't come on.  I think it's kind of a half-baked system.
Johnathn
Back to Top View Clayton's Profile Search for other posts by Clayton
JoeyCrack
Posted: Feb 28 2006 at 3:55am | IP Logged Quote JoeyCrack
I also had the same problem...the dreader cold weather tire light.  I've never found much of an issue with the tire pressure.  My advice is to obviously consider it a possible low pressure situation but don't panic something about cold weather seems to freak the system out
Loving All Things Titan
