06titan Newbie
Posted: Oct 15 2006 at 10:44am | IP Logged
2 weeks i bought a new 06 4x4 titan with the tow package, the second day i had it i pulled me boat when i was backing the boat back in up a small hill and i put it in 4 wheel high no sooner than i done that and the truck motor starts cutting in an out just like you had water in your gas it finialy stopped an i got the boat in, i thought it was bad gas? 2 days ago i had the boat back out an when i was backing in back in again the samething happen in 4 wheel high an low i had bought gas from another place so i really don't thing it is gas any ideas?
hotty69792000 Newbie
Posted: Oct 21 2006 at 10:39am | IP Logged
sounds like a week fuel pump . need to check the fuel pressure with the truck in the same postion you are in when the truck does this . also check fuel pressure reglator
bigbear05 Moderator Group
Posted: Oct 23 2006 at 7:53am | IP Logged
Yeah I would check the fuel pump too. I take it you didn't wait 750 miles for break-in before you towed anything?
