Subject Topic: tire pressure alarm Post ReplyPost New Topic
foonanas
Posted: Dec 05 2006 at 7:39am | IP Logged Quote foonanas
I had this alarm go off about 2 months ago when it got a little cold here, but then the next morning it went off.  Well I just took my first snowboarding trip of the year on friday and no problem until sat morning.  the same thing happened, and the light stayed on the rest of the time i was at the mountain.  it finally went off on the way home.  then this morning it happened again.   any thoughts on whats going on?
Back to Top View foonanas's Profile Search for other posts by foonanas
Mitch
Posted: Dec 05 2006 at 7:43am | IP Logged Quote Mitch
When its cold your tire pressure is falling belowe 28psi and when it warms up the pressure is going up just enough to turn it off. Check your tire pressure in the morning when its the coldest and bring it up to 35psi.
Mitch
bigbear05
Posted: Dec 05 2006 at 7:51am | IP Logged Quote bigbear05
And if that doesn't fix your problem. Take it back to the dealer and have them re-set the TPMS.
foonanas
Posted: Dec 05 2006 at 9:33am | IP Logged Quote foonanas
so i have low tire pressure then.  ok i will try that and see how it goes.  thanks for the quick response.
foonanas
Posted: Dec 11 2006 at 8:16am | IP Logged Quote foonanas
so that fixed the problem.  thanks a bunch
pied_piper
Posted: Dec 13 2006 at 8:34am | IP Logged Quote pied_piper
quick to the point: these tire sensors suck. kind of bi-polar.
