Subject Topic: Braking Post ReplyPost New Topic
VENDETTA
Posted: Jun 16 2004 at 6:56pm | IP Logged Quote VENDETTA
is just my brakes or is anyone else having to push thier brakes like really far to make a complete stop or just to slow down a bit....should i get this checked out or is this normal?
Back to Top View VENDETTA's Profile Search for other posts by VENDETTA
jaysonstuart
Posted: Jun 16 2004 at 7:39pm | IP Logged Quote jaysonstuart
I haven't had that issue but I have noticed a sort of a thud feeling in the pedal when I come to a complete stop.
Back to Top View jaysonstuart's Profile Search for other posts by jaysonstuart
Posted: Jun 16 2004 at 7:57pm | IP Logged Quote EvilPeppard
I have had to make two emergency stops so far and the computer assisted braking was VERY noticeable to me.  The truck felt like it was compensating for my emergency maneuver and understood I needed to brake fast.  Thing felt like it stopped on a dime...way better than my previous 2001 Ranger 4x4 did.
6thsense
U.S. - Virginia
Posted: Jun 28 2004 at 11:16pm | IP Logged Quote 6thsense
I have noticed that the parking brake is really mushy and goes way down...
mytruck04
Posted: Jun 29 2004 at 1:01pm | IP Logged Quote mytruck04
Just last weekend I went took the truck up the mountain thru some slopes and curves. Then the truck started vibrating while braking with fully loaded truck with 6 full-size people and about 400 lbs. of camping gears. It also did not feel as if there was not enough clamping power on those rotors and took longer distance and time to stop.
I believe the rotors may have warped as I read a few others at other sites having the warped brake rotors. Will take it back to the dealer for this vibration while braking. I heard somewhere that Nissan is planning on a possible recall for the brake rotor change. Does anyone have any information on the brake warpage and may have encountered similar braking problem? I now have 6000 miles on the truck.
Thanks for feedback.
Mytruck04
Back to Top View mytruck04's Profile Search for other posts by mytruck04
