Subject Topic: oil filter Post ReplyPost New Topic
vector6
U.S. - West Virginia
Posted: Oct 10 2004 at 7:39pm | IP Logged Quote vector6
does the oil filter look puny to anyone else or just me..?
 I mean come on.. my Harley's have bigger filters..
2006 JEEP Rubicon
No News with Combat Crews!!
Back to Top View vector6's Profile Search for other posts by vector6
critter
Posted: Oct 10 2004 at 9:54pm | IP Logged Quote critter
it is a small filter.  i'm not sure why it's such a small filter.  i use the fram tough guard and the number is 7313 (i think )
Red Brawn Titan LE 4X4 KC w/ Big Tow and Offroad Packages. Also has Valentine One, Truxedo lo profile, bug shield, and bed rails.
Back to Top View critter's Profile Search for other posts by critter
305hp
Posted: Oct 10 2004 at 10:22pm | IP Logged Quote 305hp
I think it'll be a problem
bdunsmore@charter.net
Back to Top View 305hp's Profile Search for other posts by 305hp
critter
Posted: Oct 10 2004 at 11:04pm | IP Logged Quote critter
i don't know....oil is so much more refined and treated these days.  maybe a large filter is required because the oil stays cleaner.  i think it's like computers.  the newer they are, the smaller they get.
vector6
Posted: Oct 11 2004 at 11:27am | IP Logged Quote vector6
the dealer told me to use "genuine Nissan Filters" to keep it in warranty...
 because of some check valve in the filter.. it supposably keeps the oil from flowing back..?
but the filter spins on with the threads up.. so the filter will stay full regardless ..right?
2006 JEEP Rubicon
Posted: Oct 11 2004 at 1:55pm | IP Logged Quote thepuffman
Unless they can prove an aftermarket filter was the cause of the problem, I dont think the mfg can legally void the warranty.....also good point about the threads pointing up......My dad was given that same line many years ago by Toyota, so he always bought their filters...since then I have "heard" that all modern filters have a drain back valve....All that being said, since its only a couple of $ difference, I prolly will go ahead and use the Nissan filter as long as it is under warranty, unless Im in a bind and cant get to the dealership...if not, I personally dont think using a Fram filter would hurt anything....
CactusJackSlade
Posted: Oct 13 2004 at 1:12am | IP Logged Quote CactusJackSlade
Just about all good filters have "check valves"... and also pressure relief valves so that in case your filter would plug for some reason the engine oil would keep flowing... better unfiltered oil than none!  The dealer just wants you to buy theirs...
I'm going to use an Amsoil filter and 100% synthetic Amsoil on this next change (around 6000 mi). Amsoil filters have better capacity (dirt holding power) and better filtering (down to 10 or 15 microns I believe).
Using Amsoil synthetic oils and filters I was doing 7,000 to 10,000 mile oil changes on my Nissan HardBody SEV6... it has 250+K on it and is still going srtong with little signs of slowing down anytime soon!... although my Titan gets driven much more these days!
If you use the Amsoil bypass oil filtration system that filters down to 1 micron they recommend oil changes every 100,000 miles! Basically synthetics do not wear out like petroleum based oils, it's the dirt that must be dealt with. Syntheti'c are much better at handling temperatures... Why do you think that jet engines run on synthetic's... because petroleum oils cook!
Just FYI Amsoil recommends 7,500 mile oil change intervals using their products. As I have said before in regards to these products, I'm no salesman, just a believer...
CJS
CJS
http://www.racemtbikes.com
SmokinT
U.S. - Connecticut
Posted: Oct 13 2004 at 8:47am | IP Logged Quote SmokinT
my dealer included oil changes free for the life of the vehicle when I bought it
Back to Top View SmokinT's Profile Search for other posts by SmokinT
Posted: Oct 13 2004 at 10:14am | IP Logged Quote EvilPeppard
I always use a filter from the dealer.  I also pick up a new crush-ring for the drain plug each time while I'm there.
Kevante
U.S. - Arizona
Posted: Oct 13 2004 at 11:15am | IP Logged Quote Kevante
If you go to the dealer you have all the service records. With your service records you will have better resale value.
CC LE Galaxy Black
