Subject Topic: soaked passenger floor board Post ReplyPost New Topic
DOBBER
U.S. - Mississippi
Posted: Nov 05 2004 at 11:59am | IP Logged Quote DOBBER
Second time to the dealer yesterday for the same problem. Has anyone noticed the same?
Back to Top View DOBBER's Profile Search for other posts by DOBBER
jdmm
U.S. - Louisiana
Posted: Nov 05 2004 at 4:05pm | IP Logged Quote jdmm
Yes,
It is a fairly common problem.
It is a design defect with the a/c drain line that allows some of the water to drain back into the cab and under the carpet on the passenger side.
I fixed mine myself in about 10 minutes with the instructions found on another Titan site. I then carried it into my dealer & showed him what I had done. He said the a/c drain issue was common & that they would have fixed it exactly like I did. Because of some story swapping I have a call into Nissan to find out when the issue will be resolved so it can be fixed professionally.
The way the drain is designed I don't understand how 100% of Titans do not have this problem.
Back to Top View jdmm's Profile Search for other posts by jdmm
DOBBER
U.S. - Mississippi
Posted: Nov 06 2004 at 7:54am | IP Logged Quote DOBBER
Thanks jdmm, all I needed was alittle push.
You know how the old story goes: IF YOU WANT IT DONE RIGHT "YADA,YADA,YADA".
jdmm
U.S. - Louisiana
Posted: Nov 06 2004 at 12:38pm | IP Logged Quote jdmm
I can email you some pics if you want to see how I did mine
DOBBER
U.S. - Mississippi
Posted: Nov 19 2004 at 11:20am | IP Logged Quote DOBBER
Thanks, found them, but it's back in the shop for the same problem. The attorneys may have to handle it from now on.
Smoke SE KC4x2
IQ9*
Posted: Nov 19 2004 at 2:44pm | IP Logged Quote IQ9*
Some times you have to get tough,even if you can fix it yourself. That is not the point.
