Videos / Photos
 Nissan Titan Forums : Videos / Photos
Subject Topic: A.R.E. Bed cover-Pictures Post ReplyPost New Topic
johnthomasc3
Posted: Sep 22 2004 at 1:32pm | IP Logged Quote johnthomasc3
As promised here are pictures of my new A.R.E bed cover.  Cost was $850 installed and that included keyless remote that unlocks and locks it.  This is a very well designed top, and I have taken pictures of the hardware so that you can see it up close if you are interested in this top.
http://pg.photos.yahoo.com/ph/johnthomasc3/album?.dir=5a2d&a mp;a mp;.src=ph&store=&prodid=&.done=http%3a//pg.phot os.yahoo.com/ph//my_photos
Back to Top View johnthomasc3's Profile Search for other posts by johnthomasc3 Visit johnthomasc3's Homepage
import2nr
Posted: Sep 22 2004 at 8:54pm | IP Logged Quote import2nr
hey i like the bed cover .. did you have to reomve the top of the bed liner that runs along the top of the bed or did your truck not come with them .. i assume they were on the truck since you have the utilitrack system in the bed pls let me know
"I can't even remember what i wanted to forget."
Back to Top View import2nr's Profile Search for other posts by import2nr
johnthomasc3
Posted: Sep 23 2004 at 6:06am | IP Logged Quote johnthomasc3
They did not have to do anything to the bedliner.  My truck has the material on the bed rails but it is hard to see in the pictures. They put cushion strips on top of it and then set the cover right on top of the strips.  They make no changes to the truck as it is.  If you want to take the cover off, you have to undo the clamps and lift the cover off.  It weighs 90lbs. so it is something that would require and extra set of hands.  I hope this helps.
import2nr
Posted: Sep 23 2004 at 6:39am | IP Logged Quote import2nr
thanks for the info
Posted: Sep 24 2004 at 3:17pm | IP Logged Quote thepuffman
Very slick looking cover...It appears that you have to lift the cover in order to open the tailgate??? Do all the fiberglass/hardtop covers work that way?
