Subject Topic: Tire presure sensor Post ReplyPost New Topic
WheelinJeeper
Posted: Feb 13 2005 at 8:35am | IP Logged Quote WheelinJeeper
I am looking at getting a set of 22" rims. What do I need to know to make sure they swap the sensor over to the new rim? i.e. were is the sensor? I have heard it is in the valve stem. So does this mean that they need to use my stock valve stems on the new rims? Or is it somewere else on the rim?
Back to Top View WheelinJeeper's Profile Search for other posts by WheelinJeeper
Cperki1
Posted: Feb 13 2005 at 11:20am | IP Logged Quote Cperki1
On most cars, there really is not a "Sensor" just for PSI in the tires.  The system works off of the wheel speed sensor that the ABS system uses to detect wheel lock up.  As a tire looses pressure it does not rotate at the same speed as the other three wheels do.  The compter will detect this difference and alert you to check your tire pressure.
2005 2WD XE
"It's for work!"
Back to Top View Cperki1's Profile Search for other posts by Cperki1
