Subject Topic: *New Volant Exhaust For Titan Post ReplyPost New Topic
premiertruck
http://www.premiertruckaccessories.com
U.S. - Arizona
Posted: Nov 16 2005 at 3:05pm | IP Logged Quote premiertruck
Volant, the innovator in Cold Air Intake Kits, has now developed a high-quality, stainless steel exhaust system for the Nissan Titan. This new exhaust system, matches perfectly with Volant’s sealed air intake for the 5.6-liter V8 engine to produce optimum flow in and out of your truck. Furthermore the Nissan exhaust is a show quality system that’s more affordable than competitive systems using a lesser grade of stainless steel. Volant’s Titan exhaust system fits 2003-’05 models and is manufactured from 304 stainless steel tubing that is mandrel bent and highly polished from end to end. The three-inch diameter tubing feeds into a 304 stainless steel, high-flow muffler that absorbs unwanted resonance in the cab but emits a healthy exhaust tone and dramatically reduces backpressure for additional gains in horsepower and torque. The system also comes with a high-flow Y-pipe that attaches to the rear of the engine’s catalytic converters and uses factory style flanges for easy installation.
Volant’s new Titan exhaust uses TIG welded construction and stainless steel clamps. Each exhaust system is also finished off with a double-wall, polished tip and the entire system bolts to the existing frame using factory hangar locations. All of Volant’s line of diesel and gas engine exhaust systems are surprisingly affordable and will improve your truck’s performance, sound and appearance
Volant Exhaust Features :
  • T-304 Polished Stainless Steel
  • CNC Mandrel Bends
  • 4" Dual Wall Tip
  • Automated Tig Welds
  • Embossed Logo
  • No Discoloration
  • Mounts on Factory Locations
  • Please Call, PM, Or Email For Your TF Member price.
    Thanks,
    David
    info@premiertruckaccessories.com
    Toll Free 888-345-4782
    Back to Top View premiertruck's Profile Search for other posts by premiertruck Visit premiertruck's Homepage
