Posted: Nov 18 2005 at 12:10pm | IP Logged
Hi All,
I have lerked here in the past, hard to spend time on multiple forums, so I usually hang out at Titantalk.com. Over there is a GB going on for the Zoomers exhaust, if you haven't heard of it, check it out. I have a video out there as well. The GB is only for 3 more days and they only need 4 more....
I have a 05 Titan, and I found this forum looking for an answer to my diff light and slip and ABS coming on. I found an answer here, which I didn't like...rear end failing, so I took it in and they tested it. They ordered me a new rear end assembly......
Yomama
