Posted: Sep 01 2006 at 11:10pm | IP Logged
Recently I had replaced my headlight bulbs for upgraded ones from sylvania since the stock ones weren't bright enough for the Montana highways at night. I popped in Sylvania SilverStars (# 9005 ST) in for the high beams and they were MUCH brighter than the stock highs, and I installed the Sylvania XtraVision (#9006 XV BP) lights in, but the results were nothing more than stock from what I could see.
I would recommend the SilverStars for the brights, but I would suggest finding a brighter low beam bulb than the XVs if there is one out there since the XVs are pretty much the same as the stock ones.
__________________ "My other ride has TwinTurbos"
